Unable to open Mechanism
pandras
Hi!
I want to a mechanism in an assembly, but Creo Parametric 2.0 alweys closes with an error massage: Unable to open $MECHANISM_HOME/text/i18n_config.mnsm
Bellow there is a photo of the massage:
Somehow i shoud solve this problem, please give me a hand with this.
P. Andras
19 REPLIES 19
asaxena
3-Visitor
(To:pandras)
Can you please share your system through Team Viewer ?
I can help you online....
sjanes
(To:asaxena)
hello
can you help me , i have the same message
Thanks a lot
can you find following files ?
MH
Martin Hanák
yes  see picture
yes
but i thing if there is at the good place
check ...\x86e_win64\mechanism\text directory. Can you find problematic file in it ?
MH
Martin Hanák
sjanes
(To:asaxena)
hello
can you help me
i have the same massage
---> Unable to open $MECHANISM_HOME/text/i18n_config.mnsm
sjanes
(To:pandras)
yes i have it
see picture
so ... the file reported in error message is present .
I do not understand why window title contains text Creo Simulate (R). Please describe what action are you doing in CR2 M220 64-bit.
INFO:
Some CR2 functionality needs Creo Platform agent (starting from M210 maintenance release). Unfortunatelly, this software is not installed automatically during Creo installation. Installation package creoagent_32_64.msi is located in C:\01-PTC_App\Créo_2.0\Creo 2.0\Common Files\M220\install\addon directory. Install Creo Platform agent into C:\01-PTC_App\Créo_2.0 directory. Installation will create Creo\Platform\2.48 sub-directory. Then test problematic action.
Good luck
MH
Martin Hanák
Hello
Hello  Martin
I install the   Creo Platform agent into C:\01-PTC_App\Créo_2.0  ,  but  i have the same message. Is not ok
Can you help me please
please describe what action are you doing in CR2 M220 64-bit. I'll try to reproduce the problem on my PC.
MH
Martin Hanák
Hy
I have the same problem again
i dont understand what hapend
here my instalation
thanks a lot for your help
I suggest you to uninstall Creo and install it again into C:\01-PTC_App\CR2_M240 directory using steps shown on you pictures. When finished install Creo Platform also into C:\01-PTC_App\CR2_M240 directory. Then launch Creo and run your analysis. If it fails, please describe what analysis you are doing (use text description and pictures). I need to know what are you doing in Creo.
MH
Martin Hanák
WHAT THAT    ---> Creo Platform
I am repeating INFO:
Some CR2 functionality needs Creo Platform agent (starting from M210 maintenance release). Unfortunatelly, this software is not installed automatically during Creo installation. Installation package creoagent_32_64.msi is located in C:\01-PTC_App\CR2_M240\Creo 2.0\Common Files\M240\install\addon directory. Install Creo Platform agent into C:\01-PTC_App\CR2_M240 directory. Installation will create Creo\Platform\2.48 sub-directory. Then test problematic action.
Good luck
MH
Martin Hanák
Hi
Can we thake a teamviewer session next week
I can't connect to your PC via Teamviewer, I am sorry.
MH
Martin Hanák
MH
Martin Hanák
