Undo component drag
lsilva
1-Newbie
Undo component drag
I've clicked on Drag Components just for testing, now my assembly is messed up.
And worse: Creo saved it !
Hot to undo that ?
Ctrl+z doesn't work.
1 ACCEPTED SOLUTION
dgschaefer
(To:lsilva)
I assume your components were not fully constrained? If so, I'd redefine them and fully constrain them.
LinkedIn
4 REPLIES 4
dgschaefer
(To:lsilva)
LinkedIn
True
It was not fully constrained.
Had to do all over
I've used the existent datum to bind the first part, instead of using the Default constraint
That was my error...
TomD.inPDX
(To:lsilva)
Use snapshots before you drag components. This gives you a quick way back.
Won't forget that on the next time
Actually, I saw that option on the Drag component window
I was thinking that "I was so careless for not to have investigated and used it the first time !", but you may agree: it is completely counterintuitive to think there is no way to undo such a change...
Thanks again guys
