Viewing in Pro E 2001
Highlighted
Newbie
Dear All, I have completed one assembly in Proe 2001. However, on screen the assembly looks like it has been blasted apart. Parts are not in their proper place as per assembly constraints. The moment I use ctrl button, and move the assembly, the proper assembly again comes into view duly assembled. As soon as I leave the ctrl button, the assembly is again blasted. I have not used explode command anywhere, and I know how to use it. Can any one help me. I think it has to do with PC capability rather than lack of Proe command. please inform the way out. thanks in advance, bhargav
Highlighted
RE: Viewing in Pro E 2001
Check if by default your explode button is pressed.try turning it off.
