Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi Folks, We notice for WF4 that we have lost the dimmed tangent edges Our config.pro setting is tangent_edge_display dimmed and we have tried menu View>Display Settings>Model Display...>Edge/Line>Tangent Edges>Dimmed but neither seems to be working. The exception is the No Display which does work. If I try either setting the tangent edges to phantom or centerline I see no effect on the screen. So in summary the settings for tangent edges Dimmed, Phantom line, Centerline do not seem to work for WF4 (M060 and M070). Does anybody have any clues as to what new thing we need to do to make this work or is it just a very annoying bug? -- Regards, Brent Drysdale Regards, Brent Drysdale Mechanical Designer Tait Electronics Ltd (www.taitworld.com) New Zealand Ph. +64 3 358 1093 This email, including any attachments, is only for the intended addressee. It is subject to copyright, confidential and may be the subject of legal or other privilege, none of which is waived or lost by reason of this transmission. If the receiver is not the intended addressee, please accept our apologies, notify us by return, delete all copies and perform no other act on the email. Unfortunately, we cannot warrant that the email has not been altered or corrupted during transmission.
