Hi, all
I have trying to assemble components into subassembly which had been activated,
but just can't find any way to get the Activate subassembly model.
model.currentmodel only can get root assembly.
Is it possible to dothat in weblink?
Any advisewill be fully appreciate
Thanks for the reply~ Andreas
Itry to use pfcselect instead, let users to point out the target subassembly.
It works well as below;
var selopts = new ActiveXObject("pfc.pfcSelectionOptions").Create("prt_or_asm");
var sels = session.Select(selopts, null);
var sel = sels.Item(0);
var model = sel.SelModel;
Pro/E will pop up a Select message window while session.Select(); (as attachment)
Is that possible to change the text "Select -2147483648 items" at will?
Shu-Fan
Thanks for the reply,
It works as below,
sels.MaxNumSels = 1;
The text become "Select 1 items".
~Shu-Fan
