Hello Folks,
What is the dialog style used in Global Interference Dialog?
Which is like, We cannot select the parts or assembly in the Graphics window, but you can zoom, rotate and pan the model in the graphics window and also keeps the highlighted interference.
I need the same type of dialog need for my application. I want to avoid the selection of parts and assembly from the graphics window but want to move or orient the model.
Right now my UI Dialog style is PROUIDIALOGSTYLE_MODELESS.
Any help guys..
Finally got answer from PTC.
It is compiled resource of Creo, So there is no possiblities to use in API
