For relations, I had found and used it once, but can't seem to any find it again. And, of course, the "Help" is no help at all..... I thought it was "||" or something.
I'm dealing with a parts list where some of the vendor parts in the assembly have no parameters at all. Since we use a relation:
IF asm_mbr_description1 == "XYZ DESCRIPTION3"
QTY_REQD = "AR"
ELSE
QTY_REQD = rpt_qty
ENDIF
If the "DESCRIPTION1" parameter does not exist, the quantity cells do not populate at all.
So, what I want to do is write the relation such that if the "DESCRIPTION1" parameter does not exist, then:
QTY_REQD = rpt_qty
I thought perhaps if I used the symbol for "NULL" instead of just " that it would work, but can;t seem to find the symbol to try.
Anyone?
Thanks!
