Why Mem Usage increases when shrinkwrap is selected?
Hello
I use shrinkwrap in my ProE 4 model assemblies, but recently
I noticed that when a shrinkwrap is open (active window), each time this part is
selected (using smart) the Xtop process increases 3000Kb of Mem Usage;
and I need to close ALL and erase not displayed parts to free memory.
The Xtop process does not reduce when I deselect or close only the shrinkwrap.
That doesn't happen when the same part is selected in an assembly.
does any body could explain it please??
what can I do to avoid it??
thank you
Gustavo C.
Tags (1)
