Wildfire 4 Family Table Issue
SOLVED
Newbie
Greetings,
I am having some trouble with a family table that I made to break down an assembly.
A component that I listed to be in Family Table Instances is not showing up when I open up those instances. I'm not sure why this is happening any input would be appreciated.
I'm using Wildfire 4.
1 ACCEPTED SOLUTION
Highlighted
Re: Wildfire 4 Family Table Issue
Thanks for the response Dale,
I was actually able to solve my problem. Turns out the part that was disappearing was restrained to a component that was further down the model tree. So when I would open up the instance in the family table it wouldn't recognize the part because it wasn't constrained to anything within that instance.
So if anyone else ever has this issue check how the parts in your assembly are constrained, and do some planning ahead of time, if I had planned my assembly model better ahead of time I wouldn't of had this issue.
3 REPLIES 3
Nick,
I was having some problems with things not showing up in tables. I am not sure if this is will help, but check out the following discussions:
http://communities.ptc.com/message/185834#185834
http://communities.ptc.com/message/185832#185832
http://communities.ptc.com/message/185814#185814
I hope this helps,
Dale
Highlighted
Go ahead and give yourself a correct answer for the answer above so that if someone search and finds this discussion, they will see how you resolved it. Thanks.
