Wire Harness errors when saving an assembly
Newbie
Gurus,
I am having a problem saving a copy of certain instances of generic
assembly models containing multiple wire harness parts.
The Save A Copy window indicated that the references for this harness have
been renamed in the generic model.
This doesn't make any sense as I can save other instances with the same
harness without a problem. I'm using WF2.
Has anyone run into this problem and found a fix?
Tony Mason.
Rockwell Automation Canada
135 Dundas Street
Cambridge, ON N1R 5X1, Canada
