Hi all,
It seems that the marked 2-2 inertia values have been replaced in every case. Iyy and Izz.
(File/Prepair/Model Prop/Mass Prop <--> Analysis/Mass Prop)
Is it normal?
Thank you for the answers.
I think the above two CSYS have y and z axes pointing in different directions.
Yes, you are right, thank you
