activate subassembly and NOT have all other models go transparent
Highlighted
Newbie
Creo 2. when i activate a subassembly  and do some external ref assembling in my huge assembly it turns a mid gray which is great but it also goes transparent which for me personally is a huge peeve and also i feel slows down everything significantly and my ability to manipulate things. how do i make it go "not transparent" and only do the color thing. ive scoured my options and havnt found anything yet. help me out if you know how.
Tags (1)
3 REPLIES 3
Re: activate subassembly and NOT have all other models go transparent
dim_inactive_components
I'm not sure whether you can make it change color only.
Maybe turn off transparency also??
transparency NO
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
turning off transparency in model display def works.
what about the yellow edge lines of cables while in mid assembly. they show up as wireframe. its annoying.
Sorry, I have no experience with cables.  There are a ton of *cable* options in the configuration editor, maybe you can try a few of them and see what may work.
Stephen Williams
