i have heard that few companies doing assembly without constraining ... they are doing by only move command(NX8.5)... How can i do those things in creo? i tried move option... but i could not understand its functionality..
You end up with nothing but a "packaged" assembly, where everything is just floating in space, not constrained to anything. I would strongly advise against it. For one thing, Mechanism will NOT work, or any of the other things you can do with a properly constrained assembly.
yes sir.. but how to do that in creo?
You are comparing apples and oranges (Creo and NX).
NX can handle the moved components much better than Creo can.
We had pre-NX and early NX users you never mated their assembly components and it was not a problem. Creo does not like unmated components.
parhaps it will be useful for you.
