can I create This Mechanism using Pro/E?
Highlighted
Newbie
Dear Simulation Gurus,
I am working with an Assembly of a conveyor...There are 3 conveyers
connected to each other with are moving at diff speed. I.e say first
conveyer is moving at a velocity of 2m/s, second at 4m/s and third at
6m/s....This is an assembly for a packaging machine so i need to move the
product (box) on these conveyors. How can i define the connection between
the conveyors and the box so that the box will move at the same speed of the
conveyors....means starting with 2m/s and will end at 6m/s.
If you need any more clarification, let me know.
Thanks In Advance,
Dharmesh.
1 REPLY 1
Re: can I create This Mechanism using Pro/E?
Dear Dharmesh,
The way to simulate this situation is to use cams with lift-off and
friction. Make a cam between the box and each of the belts, three in
total. Enable friction and gravity and carry out a dynamic analysis. The
box should transfer from one belt to the next. It it doesn't then you may
need to adjust the speeds of the belts.
Hope this helps,
Rod Giles
Elite Consulting Ltd.
Mechanica Specialists since 1993
> the
> Thanks In Advance,
> Dharmesh.
