context menu bug in Creo 2.0
SOLVED
Re: context menu bug in Creo 2.0
Hello everybody,
any news here?
We have the same issue in Creo3 M090/M100 and we use SpaceMousePro too.
Jochen
I don't have one, but have you tried new SpaceMouse drivers? Looks like they put up new ones today.
I checked Your "Repaint" method several times.
It works when the odd menu bug occurs and also when preselection highlighting is not working properly.
Thanks for Your solution.
We have updated our space mouse driver to the latest version but the problem still exists. After working a while in Creo context menu does not appear anymore.
It seems happening mostly in drawing mode.
Any new ideas? Thanks.
Huh ... I have been using the brand new Spacemouse Enterprise for 4 months now with Creo 3.0 problem free. But this week, I now have this problem too.
I shall try the Repaint solution now... I have no idea what STRG R means.
STRG R is the german keyboard equivalent to CTRL + R
Highlighted
Ah! Thank you.
Figures ... this hasn't occurred again since finding this potential solution. Curse you Murphy!
That fixed it!  Thanks!
Ctrl-R worked for me, but only from the model file, not from the drawing itself. Thanks!
