creo 3.0 Intelligent Fastener Extension, can we add new parameters to the file?
SOLVED
Highlighted
Participant
ok loving the new lite Intelligent Fastener Extension, but
what i want to know is how do i add new parameters to the entire family?
i know i can add them at the part level every time i use them
but i want them to be default parameters and not something i have to muck on with every time.
for example
ASSY1=BUW_NAME
ASSY2 = BUW_SIZE
MATERIAL = PTC_MATERIAL_NAME
MAT_DESC1 = BUW_NAME
MAT_DESC2 = BUW_SIZE
these are parameters that i use in all of my start parts so that they work with my default bom
also having the part name in lowercase is a bit crap as well but that's minor
so where is the part or spreadsheet or what ever it is
ideas?
1 ACCEPTED SOLUTION
Highlighted
Re: creo 3.0 Intelligent Fastener Extension, can we add new parameters to the file?
Short answer, NO. Long answer below.
All the models used are stored in the following location:
<loadpoint>Creo 3.0\F000\Common Files\afx\parts
You can drill down deeper to see specific fasteners. For example, Holokrome screws are here:
<loadpoint>Creo 3.0\F000\Common Files\afx\parts\screws_and_pins\screws\HoloKrome
From a cursory look, it would seem that a part without a family table is loaded, then the family table itself is created from the .dat file, then finally the specific family table instance is saved as a stand alone part for use in your assembly. This whole technique is NOT going to play well with a PDM system.
I opened one of the parts and added my own parameters. Unfortunately, as soon as you attempt to place a new fastener with the modified part you get a pop up saying you can't use it.
There seems to be some pretty touchy file checking that is making sure you haven't changed anything.
One more weird fact, I found it fascinating that the part I modified (hk-shcs-unrc.prt) was last saved in 2004 using Pro/e version 2001. Pretty old parts.
20 REPLIES 20
Highlighted
Highlighted
drat.
so i might be able to change them if i have the full version of ifx?...
i can see the conversation now,
"hi cfo i would like to get x amount of licences that let me draw bolts in our cad package"
" what have you been doing in the past "
"well we could draw bolts but it took slightly more time"
" so why do you need this new thing then?"
"its faster and does a lot of the work for me"
"how much it it"
"its $xxxx.xx per seat"
"ಠ_ಠ"
"ill just go back to my desk"
hrmn i could change the bom table to have a second sub table for just fasteners
might have to go with that
Highlighted
More PTC spam... I haven't found a single occasion for Manikin lite either.
Highlighted
You can turn it off it you don't want to see it. From the Read Me document:
To turn PTC Creo Intelligent Fastener Extension off, set the configuration option
intelligent_fastener_enabled to no and restart PTC Creo Parametric.
Highlighted
Cool! Spam with a switch
Highlighted
I don't see a way to turn off Manikin, but you can disable AFX and the learning connector.
By default the Learning Connector is active. To disable the Learning Connector set the configuration option
enable_learning_connector to no.
To disable the Advanced Framework Extension (AFX), set the configuration option afx_enabled to NO.
Highlighted
good to know,
thats going into the config.sup file asap
Highlighted
Tom,
I am unable to get this option to work. I have it set to no in my config.sup and config.pro located in the Common Files\text folder.
intelligent_fastener_enabled no
Creo 3 M030
Thank you in advance,
Lance L.
Highlighted
You need both of these:
afx_enabled no
You can't turn off IFX unless AFX is also off.
Highlighted
Tom,
I added those two options to my config.sup and it worked, turned it off and removed it from the toolbar. I did a further test and added them to my local config and set them to yes which turns it back on.
I thought the config.sup is used to set thinks that you do not want overwritten?
I think it is time to open a case with PTC.
Thank you for sharing the information.
Lance
Highlighted
Yes, please do, and let me know what they say. The config.sup is not supposed to be able to be overridden.
Highlighted
This is why I have created my own family tables with almost 11K parts in them in the past 18 months. We looked at IFX but when we heard the price to get the full version, decided to spend the money on something more productive.
I doubt these are the old pro_library file parts as IFX is licensed from B&W, so PTC has to make a profit on each license they sub-license.
Being individual part files is just not the best way to manage families of parts!
Highlighted
Just out of curiosity, what did you get instead?  Did you buy a different product or are you just using mapkeys and/or custom built automation to place fasteners?
Highlighted
We continue to place fasteners manually. Only the top level assembly has a significant amount of fasteners in it. If we make a new top level structure, we usually copy the last one over and then make mods.
Highlighted
Definitely not trying to sound like a sales guy here, but if you ever decide to purchase IFX, you can use all of your existing (11,000) fasteners with it, fully integrated with Windchill.  You don't have to use the ones that ship with it.
Highlighted
We have put all our fasteners (bolts, nuts, plugs, rings, pins, etc.) in an Interchange Assembly (IA).
Each fastener has a Component Interface (axis and plane) to make it easier to (re)place them.
And the IA gives us the huge benefit that we can swap any component for any other component. Place a bolt, swap it for a pin...place a ring, swap it for a plug...go nuts! 😉
Highlighted
So, those of us who've paid maintenance for years and, I believe, once paid extra for Pro/Library to get a bunch of poorly modeled, family table driven fasteners that hadn't been touched by PTC since the early 90s now get to pay again (and likely for the same parts) if we want "intelligent" (but likely still poorly modeled) fasteners?
Yep, sounds like PTC.
LinkedIn
Highlighted
And don't forget, prices go up this quarter for -everything-! Remember, recycling is a green thing to do
Highlighted
Going back to the original question can I add custom parameters
Using param_relations.txt you can define all teh relations and parameter you want. However as most people have already stated you will require the advanced version.
thanks, Jim
Highlighted
i think im going to turn it off for the entire office. what a waste of time
