creo3 rename parts in assembly mode?
SOLVED
Participant
hi
We just moved to creo 3.
Unless i am being stupid I cannot rename parts in assembly mode only the active assembly.
Previously you where able to select individual parts in the assembly and rename in the assembly environment.
Now i have to open the individual parts and rename each file in part mode.
Am i missing something? this seems backwards from previous releases.
We don't use windchill or any other data management.
Dan
1 ACCEPTED SOLUTION
Highlighted
Re: creo3 rename parts in assembly mode?
Ha simple?!
Thanks for the tip!
DanB
3 REPLIES 3
according to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS179098 this is current Creo 3.0 behaviour.
Alternate Solution in assembly mode:
  • File > Manage File > Rename
  • Click OK without changing the assembly name
  • Use the upcoming Assembly Rename dialog to rename individual components
MH
Martin Hanák
Highlighted
Ha simple?!
Thanks for the tip!
DanB
Don't forget to mark it as answered if that worked.
