cross section problem
Newbie
I created a cross section of a mold assembly and it appears
to have no errors. When I entire DETAIL mode and attempt to
place that view (front) on my sheet I get an error message
"Cross-section creation in view "new_view_1", on sheet 1, aborted"
any ideas what the problem could be and where I might look
to correct it?
I don't have any geom checks and in assembly mode the section
appears to have no problems.
Thanks in advance.
RE: cross section problem
i am getting the same problem, my orignal dwg was created in pro/2001 and now i want to add a node to x-section but when i "checked/In" my drawing and retrieve back (intra 3.4) it shows no x-section , even when i go a frame back before check/in it shows the correct drawing.
if u move the mouse around it shows a hatching but there is no part boundry.
it is also observed that there are few ghost objects with no reference shown in report , and i try to update them any nothing happens then i deleted them.before checking/in intralink
can any bdy suggest
i am using WF 2 M150
Intra 3.4
