HI,
In AFX,Connectors and Equipment use lots of udfs for design,this is nice for design the similar fetures .
There are three files about udfs in part mode,
1. D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\connectors\steel_construction_mm\no_standard\beam_end_cope.tab
D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\udfs\beam_end_cope.gph
2 D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\connectors\steel_construction_mm\no_standard\beam_end_cutout.tab
D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\udfs\beam_end_cutout.gph
3 D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\connectors\steel_construction_mm\no_standard\pipe_squash.tab
D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\udfs\pipe_squash_cyl_ref.gph
We can very well use three udfs for design and modify variable dimensions via menu of "modify connectors element" ,
Variable size value can be updated automatically.
If I define udf for design , for example , I set up a cylindrical feature of udf , and then join this udf name to the sel file.
2_winkel asm_copy
beam_end_cutout udf
beam_end_cope udf
pipe_squash udf
z_zhu udf
dir_up dir
sure set up the load files
D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\connectors\steel_construction_mm\no_standard\z_zhu.tab
Z_ZHU.TAB:
BEGIN_ASM_DESCR
IF_1 ELEM_NEW
CONFIG_ELEM
END_IF_1
IF_2 ELEM_EXIST
USER_SELECT FACE PLACE_SURFACE
USER_SELECT FACE YZ_SURFACE
USER_SELECT FACE XY_SURFACE
USER_PARAM_INPUT H
USER_PARAM_INPUT W
END_IF_2
CREATE_UDF z_zhu PLACE_SURFACE z_zhu
UDF_REF PLACE_PLANE PLACE_SURFACE
UDF_REF PLANE_YZ YZ_SURFACE
UDF_REF PLANE_XY XY_SURFACE
UDF_DIM H H
UDF_DIM W W
END_CREATE_UDF
END_ASM_DESCR
BEGIN_GUI_DECSCR
USER_SELECT FACE PLACE_SURFACE 1
USER_SELECT FACE YZ_SURFACE 2
USER_SELECT FACE XY_SURFACE 3
USER_INPUT_PARAM DOUBLE H 20
USER_INPUT_PARAM DOUBLE W 20
END_GUI_DESCR
D:\Program Files\PTC\Creo 3.0\M040\Common Files\afx\parts\udfs\z_zhu.gph
Then, we can use this udf loading into part file in afx, but if we modify this udf via menu of "modify connectors element" ,
The message bar prompt "No components selected by automatic intersection",
Variable size value cannot be updated automatically
WHAT HAPPEN ?
this message is not created by AFx but by Creo itself. It Looks like you are trying to create an UDF with a cut Feature in an assembly model (not in a part model).
Does the surface you select as PLACE_SURFACE belong to part or to assembly?
If you do not get it working you can send UDF + tab-file + model to test + short description of picks how to reproduce issue to me then I can check
Stefan
