Hy there
Of my asm the light keep orange even after regenerate.
There is a document made with the following messages.
[1]REV_SM_U_BEAM_15 regeneration completed with 1 suppressed feature(s) or component(s).
[1]Line 157 part REV_SM_U_BEAM_15: Invalid symbol 'G_TYP_S_' found.
[1]WARNING: Some constraint relations are no longer satisfied in REV_SM_U_BEAM_15.
[1]Automatic regeneration of the parts has been completed.
[1]Line 2 assembly KIPPERBAK-REV: Invalid symbol 'DISTANCE2:FID_584' found.
I know the parts to find but part15 is 5 times on the asm. Where the symbol is found I dont know.
How to correct the constraint relations of an EFX part is hard to find out.
Can anyone help me to turn the light on green an no more messages?
Regards and waiting for an answer.
Chris
Hi
Sorry as you can see further on it should be EFX. The application for profiles.
Regards
Chris
Hello Christiaan,
it looks like there you have customized EFX to add your custom relations to the profile parts, but your custom relations seem
to contain some errors or problems.
If you like you can send me the model by E-mail then I can check
Stefan
