explode view
Newbie
explode view
I have created an assembly with parts and other assemblies, I want to explode the view in a way that the sub-assemblies stay intact and only the parts are exploded
RE: explode view
If I understand you correctly, you want to move the subassys and parts as units. Do as you use with parts regarding to everything but when you select use the Model Tree, click on the sub-assy and move it. It will then move as a unit. Hope this covers it ... PS: Sometimes I use "Copy Pos" with small sub-assys (only 2-3 part).
Re: explode view
There is a tutorial you can watch on the ptc website. I hope this helps.
Bill
http://http://learningexchange.ptc.com/tutorial/764/moving-and-exploding-parts
