exploded assembly
Newbie
exploded assembly
Trying to create an exploded view to put on a drawing.
Is there a way to get the explode status to show up in the model tree? I
added the status column and all that tells me is it's regeneration state.
Then, if I do get all my parts set and moved around, how would I go about
getting the drawing view to show the assembly as I left it?
When I set my view to exploded it only moves the parts to the default
location on the drawing, not where I moved them to in the assembly mode.
This is a family tabled assembly.
WildFire if you hadn't guessed.
Thanks for the help
Dave
