family table verify file
ptc-154724
To all, Does anyone know if PTC is going to add any "useful" information to the family table verify file (.tst file) that gets created other than the following: Instance_name of model Regenerate status 3_35_LAYOUT_1000GB 3_35_LAYOUT Success 3_35_LAYOUT_1350GB 3_35_LAYOUT Failure 3_35_LAYOUT_1600GB 3_35_LAYOUT Failure 3_35_LAYOUT_1800GB 3_35_LAYOUT Failure 3_35_LAYOUT_2000GB 3_35_LAYOUT Failure 3_35_LAYOUT_2250GB 3_35_LAYOUT Failure The status of "FAILURE" is no help to me, as I would like to know what the FAILURE is, to look to fix the problem. I open the instances that failed and they regenerate successfully, with no errors, then when I verify the assembly again, it now passes. Dennis
0 REPLIES 0
