family tables
Newbie
family tables
AHhh my favorite subject.... family tables.
I have an assembly with a subassembly. I would like to hide a component
in the subassembly in one view of my drawing.
Now I found out I can not supress a component in a subassembly in family
tables. OR can I????
I have my top assembly open, go the path of making a family table and
select components. But see there, it won't let me pick any components
from the subassembly.....
If this is not the way to do it, can I do this over my view manager??
Any ideas??
Or do I just not see the trees because of the forest...
Christine
RE: family tables
Hi Christine,
The first family table should be in the subassembly.
Then put one in the main assembly.
Best regards,
Frederick W. Burke III
Mechanical Design Engineer
ISE Corporation
7345 Mission Gorge Road, Suite K
San Diego, California 92120
(619) 287-8785 x-151
RE: family tables
Christine,
For what you are trying to do, Family Table might not be the best solution. Have you tried to use Member Display functionality in Drawing (in 2001 - Views > Disp Mode > Member Disp > Blank)?
Or put that component on a layer and blank that layer in a particular view?
Eugene Elenev
CAD Systems Supervisor
ASML
77 Danbury Road (203) 761-4040 - phone
Wilton, CT 06897 (203) 761-4259 - fax
>>> "Frederick Burke" <-> 04/22/04 04:51PM >>>
Hi Christine,
Best regards,
ISE Corporation
