has the issue with save copy assembly window addressed in Creo 2.0 M040?
rohit_rajan
has the issue with save copy assembly window addressed in Creo 2.0 M040? it is not scalable properly ? many options on the window just go below the screen...
7 REPLIES 7
vzak
6-Contributor
(To:rohit_rajan)
Rohit, which screen resolution do you use ?
rohit_rajan
(To:vzak)
yeah i know i have to use 1280X1024 atleast. but that's not the point.
we are a ATC and have 15 systems on creo 2.0. our monitors do not support that or more resolution.
can't a scroll bar or slider be added so that guys like me do not have to buy 15 new monitors.
Thanx
I have to back Rohit on this one. Today, the "standard" screen resolution is 1366x900. Even a high ends mobile workstation like a Dell Precision M6600 is 1600x900 resolution. It was only by luck that I got the upgrade to HD.
This requirements for a minimum of 1024 vertical resolution is outdated.
i hope they see some sense in it!
vzak
6-Contributor
(To:rohit_rajan)
Gentlemen, to make a long story short : you are right this was a mismatch while UI change.
This will get fixed shortly - in the next available Creo02 datecode (I guess it will be M070, but do not catch me on this). The issue that will be fixed is a general "Window Resize" behaviour of dialogues like Save a Copy, Simprep Definition, Mirror Assembly. It will not appear smaller on the low resolution screens but you will be able to easely resize it and pull up.
TomD.inPDX
(To:vzak)
Thanks for the insight, Vladimir!
rohit_rajan
(To:vzak)
this is a great news..... thanks...
