I am using EFX Framework for designing SAE car.In this for the pipe profile in inches, there is predefined shape Profile in library but I have to choose my own dimensions for pipe. How I add dimensions in this framework?
I have to add - pipe profile in inches 1"OD and 0.12" wall thickness and 1"OD & 0.062"wall thickness.
Thank you.
Waiting for reply.
There are two ways to do this.
1. After importing profile you can edit the existing sketch.
2. You can create your own library for parts with vary ranging, so that it will appear in your profile list.
How to add a profile doucment may be available on PTC KB or on B&W portal.
Amit
