can anyone tell me????
Can you specify your problem ? Tell us more.
I need to create the datum coordinate for components (fix constraints part) and I need to change the constraints automatically through this particular comoonent created coordinate and assembly default coordinate. jlink coding
How the coor sys should be created ? On existing geometry or predefined reference or .. ?
new coordinate system should be created on the particular part (only that the part is fix)....
