how to give a name of exported dxf files automatically according to parameters
SOLVED
Newbie
hello,
I would need a help with autoranaming exported dxf files according to two parameters.
The first part of the name would be name of the top level assembly (for ex.473-4445) and the second one a local parameter of the exported part (for ex. P1)
The full name of the exported dxf would be 473-4445_P1
Thanks for help in advance
T.
Re: how to give a name of exported dxf files automatically according to parameters
Tomas,
e:\users\hlavinkat\creo\config.pro must contain: bom_format E:\users\hlavinkat\creo\mybom.fmt
I made a mistake in previous Reply.
Because DESKA_ORBIT_ drawing is placed on sheet inside 473-4439.drw (assembly drawing), there is no simple method how to fulfil your request.
Automation would be possible, if separate DESKA_ORBIT_.drw exists for DESKA_ORBIT_.prt.
So we can "close" this Discussion.
Martin Hanak
Martin Hanák
10 REPLIES 10
Tomas,
to be able to automate some activity, you have to be able to describe how do you do that activity manually.
In you case:
> How do you get assembly name ?
> How do you get parameter value ?
If you know the above information, you can use AutoIt/AutoHotkey to record manual steps.
Martin Hanak
Martin Hanák
assembly name is a model name of top level assembly (pic1)
the parameter value is actually a bouble number made by integer and some extra symbols added (pic2, paremeter DXF_NAME)
the name of exported dxf should be 473-4439_P1 in this case
Tomas,
my guess about what you want to do is that:
  1. you want to open an assembly, for example 473-4439
  2. you want to export something to DXF format, for example DESKA_ORBIT_ part
Question: Which objects do you want to export ? Are you sure that they contain DXF_NAME parameter ?
Top assembly ?
All subassemblies ?
All parts ?
Question: Do you want to export 3D models into 3D DXF or their drawings into 2D DXF ?
Martin Hanak
Martin Hanák
ad 1. - yes
ad 2 - I want to export all parts of the assembly 473-4439 which are made from a metal sheet (for laser cutting CNC machine). The parameter DXF_NAME is in start_part_solid_prt template so I need to export only that prts starting with "PL" in parameter ROZMER.
the export format would be 2D DXF
Tomas,
this means:
  1. you open an assembly, for example 473-4439
  2. you need to get list of parts, which meet the condition ROZMER="PL*"
Tip:
Create mybom.fmt containing 2 following lines:
.breakdown
.row %$name;%ROZMER;%DXF_NAME
Put the following option into config.pro file:
bom_format PATH_TO_DIRECTORY\mybom.fmt
Open the assembly, activate Model tab and click Bill of Materials from Investigate group.
Creo creates text file 473-4439.bom.1
You can open this file in Excel or Notepad and filter parts, which meet the condition ROZMER="PL*"
So you have the list of parts.
Questions:
How do you find parts and their drawings ?
Is drawing name same as part name ?
Are drawings and parts located in the same directory as top assembly ?
Martin Hanak
Martin Hanák
Martin, I exported the 473-4439.bom.1, opened it and saw it looks like this: "1 Part DESKA_ORBIT_". It means number of parts in assembly and a model name.
I quess there is a problem with the fmt file path - am i right? I put the fmt in working directory and in the folder where is the config.pro
everything (assembly, parts,drawings) is saved in the same directory called 473-4439.
all those drawings are in one drawing (called 473-4439.drw) containing top level assembly, subassemblies and prts in several shhets.
Tomas,
on my PC:
  • my working directory is set to ... D:\tmp\creo
  • Creo 2.0 startup directory is ... D:\tmp\creo
  • D:\tmp\creo\config.pro contains the option
bom_format bom_format D:\tmp\creo\mybom.fmt
  • bom_format D:\tmp\creo\mybom.fmt contains following lines
.breakdown
If I understand you well 473-4439.drw is the only one drawing in 473-4439 directory (multisheet, multimodel). Is it true ?
Is DESKA_ORBIT_ drawing included in 473-4439.drw (this means that specific sheet of 473-4439.drw contains DESKA_ORBIT_ drawing) ?
Martin Hanak
Martin Hanák
working directory: c:\users\hlavinkat\Documents\473-4439\22 - kopie
Startup Directory: e:\users\hlavinkat\creo\
e:\users\hlavinkat\creo\config.pro contains: bom_format bom_format E:\users\hlavinkat\creo\mybom.fmt
mybom.fmt in e:\users\hlavinkat\creo\ contains:
.breakdown
the second part of your answer - yes its true
Tomas,
Martin Hanak
Martin Hanák
