how to increase the number of allowed rows in assembly parameter list?
Highlighted
Regular Member
When requesting sublevels as filter in assembly parameters
I am getting this error message
What to do?
Essentially I only interested in exporting the PRO_MP_VOLUME - parameter of each and every part in this assembly.
Any alternative ideas?
Highlighted
Re: how to increase the number of allowed rows in assembly parameter list?
please open Case at PTC Support.
MH
Martin Hanák
Highlighted
You can export the value of this parameter by exporting the contents of a customized model tree:
- step 1) show only assembly components in the model tree (uncheck from being displayed: features, placement folder, and all the rest)
- step 2) remove all columns and then add column for the model parameter "PRO_MP_VOLUME" (also listed in the type mass-properties parameters)
- step 3) export the contents of the model tree
Highlighted
Thanks a lot!
