Hi Team,.
For example I have 100 feature (including parts & assemblies) in main assembly model. I need to segregate the BOM table based on assembling sequences, like first 10 features are stage#1, next 50's are stage #2 and goes on.
How to make these into BOM table ? some parts & subassemblies are may repeat in further stages...
I thought to add simplified rep. report symbol in BOM table to segregate, but I couldn't find such report symbol for simp rep.
Then I was searched report symbol for feature ID in assembly components, this also I didn't get..
please share your ides to do it.
Thanks in advance.
The best way to do this type of thing is with Pro/PROCESS, or process for assemblies. You take any assembly and drop it into an environment where you create assembly sequence steps. Each step has the BOM for that step, balloons, and you can also create explode states. Not sure if it is part of your package. There was just a thread on it last week. You'll see if you have it when you create an assembly.
