location for a part in a ansembly file
SOLVED
Regular Member
hello i have a asembly file , i open a part from assembly but location in my disk how i find it
sometimes i use in many ansambly same part but i forget the fille for this i open an assambly but i dont know how i open the path for this fille
some suggestion please
tks people
1 ACCEPTED SOLUTION
Re: location for a part in a ansembly file
Use the config option: display_full_object_path
Controls the display of the object's full file name (including its object-type suffix and its version number) and file path in the window title and Model Info display. Yes - Displays full file name and file path. No - Displays object name only.
defaults to no, yes    no
Redro,
start using SEARCH_PATH config.pro option (see Help for an explanation).
Martin Hanak
Martin Hanák
