I apologize if this is beating a dead horse or an easy question, (I did do a search).
We would like a simple "h" mapkey to hide and unhide the selected model/assembly, either in the model tree or graphics area.
I appreciate any insight.
David T. Francis
I think I remember we tried it....but found the middle mouse function to be an issue. I cannot remember if we ver got it to work correctly.
All....I meant RMB not middle.
In the attached config.pro file there are 3 mapkeys that I find usefull for hiding and unhiding parts / sub-assmblies while working in upper level assemblies. You can append this to your local config.pro file in your startup directory
hc --- Hide the selected component
spo--- Select parent object usefull for selecting the sub-assembly level of the current selected component.
ua--- Unhide all
Also you can use Ctrl+z to undo the last hide & Ctrl+Y to redo the last hide.
Dave McClinton
Sr. Mechanical Designer / MCAD System Admin
"RCP"
Richardson Cooling Packages, LLC
731 Moravia Street
New Castle, PA 16101
Phone: 724-698-1015
Fax: 724-652-4142
Email:dmccl@coolingpackages.com
Web:
Hi Dave,
Do you still have these mapkeys in a config? I can't find the attachment.
BR,
Heidi Åman
Attached is a config.pro file of the Mapkeys mentioned
These were created in CREO 2.0
Yo can append these to you local config.pro file
Dave McClinton
Xylem@
Thank you
