Hello, I would have this problem, last Friday the customer came to see the assembly of the machinery I have completed, the overall assembly of the machinery is divided into many sub-assemblies as indicated by the customer. The the client asked that for each sub-assembly, the relative ASM_DEF_CSYS must coincide with the ASM_DEF_CSYS of the general assembly, so that the group/subassembly can be removed and replaced with another of similar function only by matching the CYSY, without having to set other constraints .
In my general assembly the subassemblies are constrained with the mate constraints and ASM_DEF_CSYS do not coincide with ASM_DEF_CSYS of the general assembly. Assuming that I have to do as the customer asks, how can I do to solve the problem as quickly as possible?
many thanks
I know this can be automated as I have done it at a previous job (10 years ago) for a customer. You may want to ask the customer if they have a program or process for this.
To manually do this try this procedure:
