missing component with custom catalog
Ronan
Hello group,
I'm trying to create a new IFX catalog, so I will ask several questions this days 🙂
at the first time, please let me wish you an happy new year guys.
and here is my first question:
I could add a custom screw, and it works with issues (this is for a next topic). when I save my assembly, close the CREO session (I use CREO4), and re open the assembly in a new CREO session, my screw is missing.
I try several things in the IFX_CATALOGS, like
1)
#screws
vis_rabourdin
2)
#screws
vis_rabourdin
1021_5_08<vis_rabourdin>
1021_5_10<vis_rabourdin>
1021_5_12<vis_rabourdin>
1021_5_14<vis_rabourdin>
or
3)
#screws
vis_rabourdin
1021_5_08
1021_5_10
1021_5_12
1021_5_14
without success.
please note that is a family table I use.
does someone can help me to understand why the component cannot be retrieve alone?
thanks in advance,
Ron
Hi Ronan,
I think you have your generic part copied to the ifx_fastener_data folder. This will not work.
Please move all your fastener to Windchill (if available) or move them to a archive folder.
Then set a Creo option search_path to this folder.
I recommend to update the index in this folder
Update IndexUpdate Index
Then the files can be found by IFX and of course by Creo if you reopen the assembly.
Oli
Oliver Gräbner
B&W Software GmbH
Hi Ronan,
Oli
Oliver Gräbner
B&W Software GmbH
Ronan
(To:OliverGräbner)
thank you Oliver, that works fine now  Smiley Happy
