pre-selection highlight and selection filter
Highlighted
Sapphire II
In WF3-M130 it seems that when you have pre-selection highlighting turned off, you don't have the "smart" option in the selection filter (lower right hand corner of pro/e).
Has it always been this way or did it just change? I've had the pre-selection highlight turned off for quite a whilenow and I didn't notice till recently that i couldn't select anything except parts in an assembly unless i change the filter.
If someone using older build of WF3 could verify if you are able to use the "smart" selection filter when you have pre-selection highlighting turned off, I sure would appreciate it.
I'm talking about the pre-selection highlight under EDIT - SELECT - PREFERENCES -uncheck the box with preselection highlighting.
Steve
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
RE: pre-selection highlight and selection filter
I've gotten a few response saying this is how it has been. I know that occasionally I use pre-highlight, I guess I am just confused. Well, really, I'm always confused, so why am I surprised.
Thanks to those diehards who responded over the weekend.
Steve
In Reply to:
Steve
Steve Williams
