pushing a coordinate system
Highlighted
Newbie
I'm working with a complex multi-part (350) assembly and I'm trying to get a common coordinate system pushed onto all of the parts, i.e. all the parts have a MAIN coordinate system. Is there a simple way to do this with opening every part and creating them individually?
Highlighted
RE: pushing a coordinate system
You could "copy Geom" the main CS into every part, and perhaps make a map key, but if you're using the same part multiple times in the assy (screws, bolts, etc.), you'll get mixed results, to say the least, because it'll copy the geometry location relative to the part the copy geom wad first used it.
