"Error writing file; check disk space or write permissions".
Parameters filled out from excel
Rich,
I agree, you do want to use a start part all of the time so you have all
of your company standards incorporated.
Once in a while you will recieve a part from a vendor, other company or a
newbie just imports it, so you have to add the parameters.
Lance Lie
Sr. Tech. Support Eng. II
310.952.4347
310-952.4452 fax
"Rich Serafin" <->
03/19/2008 07:47 AM
Please respond to
"Rich Serafin" <->
To
cc
Subject
[proecad] - RE: Parameters filled out from excel
Lance & Co,
Is there some reason you wouldn't want the imported files to use the start
part files? We use the config.pro option "intf_in_use_template_models"
>yes to force STEP, IGES, etc. to use our start part template. That way
we've got our parameters, datums, layers in the model. The user just tells
Pro/E to open the import file and it automatically contains our standard
info. Just a thought.
Rich
-----End Original Message-----
Rich,
That is a good tip. It will be implemented within minutes.
Curtis Odom
CAD Manager
BLACK & DECKER HHI
19701 Da Vinci
Lake Forest, CA 92610
Re: "Error writing file; check disk space or write permissions".
I am still getting this problem in. 5.0. It's the student version and I'm using it for class. I don't know if it has anything to do with saving files to a flash drive.
