Whenever I create a new part or assembly, the "New File Options" (where you can pick your start part/asm) window always opens up behind the main Pro/E window. If I minimze Pro/E and them bring it back up, then the "New File Options" window comes back up on top. I've just dealt with it. Has anyone else seen this, is there a fix so it opens up on top?
Creo Elements/Pro 5.0 M100
Thanks!
Ted
