"Smart Heap Error. Out of Memory"
Regular Member
Dear all,
I'm working on an main assembly with skeleton and map part, and the file
size is about 800M byte data. After I've open the assembly and tried to do
some work, it "kick" me off with an error of "Smart Heap Error. Out of
Memory".
Mine PC virtual memory has been set to the highest of 2G byte.
Both storage drive and system drive has about 1.5G free space.
My operating system is in WindowsNT 4.0 plateform.
Pro Engineer 2000i
I would like to know if anybody has encounter the similar problem? Could
the Skeleton or the map part be the "culprit"?
Any help will be appreciated.
Thank you 🙂
Eileen
