Quilt can be exported in the .obj format ?
Please, could you explain how to do this?
Thank you very much
Marta
David,
you can use the SearchTool (Ctrf+F) for this. Switching to the Search
Tools History tab and mark Rule "All" will allow you to find all Quilts in
one go.
If your quilts have been given names you can also use the Attributes tab's
Name rule, but Quilts do not have a default name, so most likely this will
not give you what you need.
Good question. I now learned that Quilts can be exported to .obj. Thought
is was only solid geometry that could be exported to a tesselated format.
Bjarne
"David Martin (Lyndale)" <->
04-05-2010 21:51
Please respond to
To
cc
Subject
[proecad] - save asm. as a .OBJ (wavefront file)
Gurus!
I am trying to save a large assembly as an .obj file. Asm. contains many
hundreds of quilts (cosmetic features, imported copy geom., etc). Finding
and selecting them all in a nice reasonable fashion is what I am looking
for insight into. I can?t believe I have to select hundreds of these one
at a time!
Thanks in advance
Dave Martin
Sr. Industrial Designer
The Toro Company
This electronic message including any attachments ("Message") may contain
information that is privileged, confidential and/or exempt from disclosure
under trade secret and other applicable law. If you are not the intended
recipient, notify the sender immediately, permanently delete all copies of
this Message, and be aware that examination, use, dissemination,
duplication or disclosure of this Message is strictly prohibited.
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailling list Manage your subscription
Use of this email content is governed by the terms of service at:
http://portal.ptcuser.org/index.php?module=sthtml&op=load&sid=s1_010_tos
