To all,
I am creating a shrink-wrap part in an assembly, but am not sure what the difference is on one of the settings. when i pick the part to add the shrink-wrap in, at the top there are two ways to do this:
I do not know what the difference is for these two and am looking for some guidance.
Also, when I go to create the shrink wrap, and pick the option of "Autocollect all solid features" it asks "Would you like to exclude internal components?" so I pick Yes for this. But when I open the shrink-wrap part, and make a section thru it, it still has the internal components in the shrink-wrap model. Any guidance on this would be greatly appreciated as well.
Thank you,
Dennis
Hi Dennis,
If the option Set referencing type Assembly context is selected, then the Shrinkwrap feature will be created using the surfaces of the assembly. But if you toggle the option to Set referencing type External, this will allow you to change the model and copy surfaces, datums, etc. from a different reference model.
The following is a copy/paste from the Help Center document - To Create a Shrinkwrap Feature
Amit
