sheetmetal: "remove material normal to both driving and offset surfaces" bug?
bp
6-Contributor
6-Contributor
Im designing a frame using square tubes. Cut-outs that are not perpendicular to the metal wall are automatically adjusted in sheetmetal modus I would like to avoid unwanted edges sticking out, for this Creo has the "remove material normal to both driving and offset surfaces" function, but I cant get it to work!
It only works when the edges are ripped and not bend. See images. Am I doing something wrong or is this a bug or did they just stop programming when they needed the recources elsewhere?
1 ACCEPTED SOLUTION
TomD.inPDX
(To:bp)
If you make the surround 1st with a seam, the extrude does work properly. Then you build whatever you need for the "floor"
10 REPLIES 10
RV_5434567
7-Bedrock
(To:bp)
I think there is a little bug in there, I've had trouble with it too.
bp
6-Contributor
6-Contributor
(To:RV_5434567)
Im wondering if the people at PTC read this forum and pick up stuff like this..?
jsarkar
1-Newbie
(To:bp)
you can report to tech support
bp
6-Contributor
6-Contributor
(To:jsarkar)
How do I do that?
Also I have a great idea: if the guys at PTC responsible for programming would all regularly check this forum (which is owned by PTC..) and even reply once in a while; that would really be efficient and give the users the illusion PTC actually cares.
jsarkar
1-Newbie
(To:bp)
you have to log a case. go to ptc support section.
ClintWalton
1-Newbie
(To:bp)
Hi BJ P,
I have this in my notes of things to follow-up on from when I read this last week. You were heard, I just did not have any sort of resolution to provide.
Is this still something you are working on or did Antonius' response get you where you needed to be?
bp
6-Contributor
6-Contributor
(To:ClintWalton)
Hi Clint, I solved this by doing the extrude twice.
Could you say if this is a bug or just something?
ClintWalton
1-Newbie
(To:bp)
I'm glad to hear you've found a solution. Without you creating a technical support case where this can be thoroughly looked into, I cannot make a comment about the behavior in that regard.
If you wish to pursue this, I encourage you to log a technical support case.
https://www.ptc.com/apps/case_logger_viewer/auth/ssl/log
TomD.inPDX
(To:bp)
GabrielZaha
(To:bp)
An square tube is not a sheet metal part. What you need to do in this case is to deactivate the "Remove material normal to surface" button.
