show texture in assembly mode...
ptc-106508
1-Newbie
How do I show a texture in an assembly??? It shows in the part and in the drawing but not in the assembly...
I am using a jpeg in the texture.
Here is the error message:
Texture or wrapped shader assignment not available on assemblies or assembly components
WF 5 m070...
Thanks for the help.
Mark Nerby
Fluke
5 REPLIES 5
Hi Mark...
This is the same kind of thing we encounter on harnesses. You simply don't have the option to use those textures at the assembly. I brought this up to PTC personnel at the Technical Committee meetings held after Planet PTC 2012 and was told to "take it up with the visualization people".
So... I submitted a request to join the Visualization TC. As for now, we have little in the way of options. I'm using a demo license of Keyshot and I'm very impressed by it's rendering capabilities.. plus it can handle textures in an assembly!
Thanks!
-Brian
Brian K. Martin
Sr. Mechanical/Application Engineer
SGT, Inc. under contract to
NASA Goddard Space Flight Center
301.286.0059 (NASA Office)
443.421.2532 (Cell)
Hi again Mark...
Sorry to double-post but I re-read your message and thought this was relevant.
You can see the textures in an assembly as long as they are SET in the part. You'd open each part, set the texture, and THEN open the assembly.
If you open the assembly and you can't see all the textures at once, try CLEARING all appearances. See screenshot below...
[cid:image001.png@01CD65DB.97F59630]
Sometimes you have an appearance set at the assembly which is overriding the appearance at the component level. Remove these assembly appearances and the part/component appearance should come through.
Thanks!
-Brian
Brian K. Martin
443.421.2532 (Cell)
All
Assigning appearances and textures in an assembly is supported in Creeo 1.0 and above. They can be assigned to any entity (part, component, component surface, etc)
Paul Sagar
PTC Product management
Paul,
Is there anywhere a "How To.." on this. The appearance tool seems to have a lot of functionality that we users seem to be unaware of. Personally, I am finding it difficult to apply after using Pro/Engineer color menus and I suspect from the forums that others are too.
The Clear All Appearances worked!!!
Thank you!!!
We are trying out a new process, creating a JPEG of a decal's artwork then using it as a texture on the part to show the artwork. That way you see the artwork in the part, drawing and assembly.
Mark Nerby
Fluke
