Could anyone outline the process between opening an stl, and beeing able to save it as a shrinkwrapped stl , with "surface subset" I have recieved a mesh consisting of thousands unconnected open edged intersecting shapes. It was made in 3D max and it's all triangle data, no nurbs. but not a point cloud either. So i can save it as STL or OBJ or another triangle based format. the overall piece is in fact beautifully modelled, and the outside appearance has to remain unchanged. So I need to produce one watertight mesh that exactly duplicates the appearance of the original. This for milling and 3D printing purposes. the "surface subset" shrinkwrap feature seems to describe exactly what I need. So, I tried toopen the .STL, i do "save a copy">shrinkwrap but "surface subset" doesn't give me any results, the whole piece is colored orange, signifying that no surfaces are beeig exported. "faceted solid" does produce a file, but it's very simpified. So i'm a total newbie in this and what kinds of surfaces and shapes and states Pro/E has, but could anyone outline the process between opening an stl, and beeing able to save it as a shrinkwrapped stl , with "surface subset" I have tried some remeshing/shrinkwrapping/shellgeneration software, which creates more points for less detail. this remeshing trick however is the only way i've found so far that creates a closed shell, too bad it's too ugly to be used. there are thousand of open edges etc, any manual approach is futile, it has to be fully automatic.
