Hi Ronan, if you want to create an animatition, try to do following steps. 1. Open a assembly (At first a little assembly). 2. Choose Applications and then Animation in this pull-down-menue. 3. Now you get a new menue which called Animation. Click it and choose the command "view@time". Now you select a saved view, perhaps Front. Click Apply. Enter a new value for the time and change then a saved view. perhaps 10 and default. Click Apply again. 4. On your rigt side you can see some icons.Search the "start the animation" icon and click on it. 5. Below this icon you can find "Playback". Click there too. Select Capture and then OK. Hope it helps. Jürgen
