I've imported a dwg from Adobe Illustrator into Pro/E. Only contour, no surfaces, no text. It's looking fine in Pro/E and even when i plot to a printer it is ok. But with the Pro/E Tiff plotter, all small curved lines are rendered wrong or not at all. See attached image. raster_plot_dpi is set to 400 dpi, that should be enough, i think.
Any idea what's wrong or suggestions? It looks like Pro/E connects the first and the last point of the curve with a straight dotted line. Is it a bug?
I am using Pro/E Wildfire4 M160
Regards
Andreas Fromm
