When creating a NC assembly (.asm) in Creo2.0, a ".tph" is created in my workspace when I save it. But if I delete it, then it seems to have no influence on the NC file.
So do I need to keep that file? or can I delete it without problem and just Check my .asm file in Windchill?
This is a tool path storage file. It is supposed to speed things up. This is always safe to deltete.
how we can disable .idx,.lst,.mbx file when we are output nc program
.tph can disable output but every you replaypath your toolpath must re calculate
