Questions, comments,concerns or even complaints?
OliverGräbner
If you have questions, comments, concerns or even complaints, post it here!
Here is a list of our products:
Main Products
Knowledge Based Engineering
SmartApps
Oliver Gräbner
B&W Software GmbH
6 REPLIES 6
I need to Know how to add standard die base library in PDX instead of editing individual plates. Is it possible?
Hi Rajesh,
there are two ways to prepare die sets:
- Create your standard die set once in the plate wizard and use File > Save. You can later on retrieve this setup by File > Open. This information is usually stored in <PDX>\configuration\my_plates.
or
- Create the Creo data of your die set and save it to <PDX>\configuration\my_diesets. You can use these templates later on when creating a new project in PDX.
In PDX 9.0 you have also the possibility to save die sets to in sub directories of <PDX>\components\<unit>\plate and retrieve these in the plate wizard by selecting supplier and size.
  Achim
Hi Achim
Thanks for your Reply..
I want to know how integrate form analysis to PDX, and where I can download that tool.
Thanks & Regards,
Rajesh D
Hi Rajesh,
I'm not sure what you mean by "integrate form analysis" and where you can download this. We don't offer an additional tool to PDX.
  Achim
Hi Achim,
I am asking about BEA (Blank Estimation Analysis) integration in PDX.
I want to know in EMX how to edit slider angle pin dia and also I want to add misumi sliders. Do you offer any std Misumi Sliders
Rajesh D
Is it possible to give space between core plate and cavity plate in EMX, If possible let me know the procedure.
Rajesh D
