Add Reported bug(s) field to the Run in Excel template
SS_10750124
7-Bedrock
If a test failure occurs while running Test Run in the browser, you can report a new bug using the Report Bug button, and this bug is automatically entered into the 'Reported bug(s)' field of the Test Run Item.
However, these functions cannot be used while using Run in Excel.
Therefore, if the user used the Run in Excel, they must create a new Bug Item and manually enter the Item into the 'Reported bug(s)' field in the Test Run.
If the number of Test Runs that need to be performed is huge, this will inevitably become a very cumbersome task.
Additionally, the Excel Import function is unavailable in Test Run Tracker, so there is no way to process this all at once.
If the 'Reported bug(s)' field value can be entered in the Excel template used in Run In Excel, the user can batch pre-registered Bug Items into the 'Reported bug(s)' field when importing the Run In Excel file. (Like the function of entering the Reference Field during Excel import of another tracker)
Hello @SS_10750124
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
