Is it possible to add a version of an item from a specific baseline to a tracker via the API?
The use case is: a test case tracker with multiple baselines -> create a test set for a specific test case tracker version.
Hi @VA_11837938
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
